Ductape
Jun 03, 2019Explorer
Is it a 50 amp service?
If its not, it's loose connections = high resistance where the burn is. Resistant at location A does not cause a burn at location B. The problem is precisely where you see it.
A 50 amp service, if miswired at the source, can potentially overload the neutral. So long as it's correctly wired to 220v, the neutral carries only the DIFFERENCE between the two hot wire currents.
If the source outlet has both 50 amp sources at just 110v, the neutral will carry the SUM of the two hot wire currents. No outlet should be wired at 50 amp /110-120v but you hear occasional accounts of people who've encountered a "cheater" 50 amp plug.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
