dougrainer
Jun 03, 2019Nomad
Your BUSS screws will appear tight because the BUSS got hot and seized some of the screws. If you have an Open/loose Neutral on a 50 amp RV, it will usually NOT burn or melt anything. It will supply 220 to the RV and burn out some appliances The Open on a 50 amp can be at the CG pedestal or on the Shore cord or at the Main electrical breaker panel. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
