MrWizard
Oct 19, 2015Moderator
thats the Neutral Buss, the wires on the right nearest the breakers burned
the heat transfer damaged the ones on the left
what/where do those right side burnt neutral wires connect to
is that part of the input shore power circuit ?
water heater, electric for the fridge
or did they just come loose and cause that heat
did the converter power section behind the panel overheat ? short out ?
you are looking at the Neutral power BUSS, not the charge converter
which is a seperate section that is also connected
and might or might Not be one of the burnt wires
you need to open up the whole thing
to find out what happen and why
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
