Caryite
Oct 20, 2015Explorer
Here's an update after IDing each of the wires along the neutral buss bar and a better picture of the bar itself.
I numbered each hole 1-7 from left to right. Here's what is connected to each:
hole 1 - converter
hole 2 - empty
hole 3 - AC
hole 4a - water heater
hole 4b - microwave
hole 5a - GFI
hole 5b - refrig
hole 6 - main (black goes into 30 amp fuse)
hole 7 - empty
All of the responses prior were focused on hole 6 or 5a/b being the problem. I think the above shot shows hole 6 on the main from shore power being the issue. Comments are welcome.
I am replacing the buss and there is plenty of wire length behind the converter to use after I've cut the burned neutral wires.
The concern is this area behind the buss that looks pretty burned as well.
Should I try to replace this as well, or just get a new enclosure for the WF-8955 distribution center?
hole 1 - converter
hole 2 - empty
hole 3 - AC
hole 4b - microwave
hole 5a - GFI
hole 5b - refrig
hole 7 - empty
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
