Old-Biscuit
Nov 18, 2020Explorer III
dougrainer wrote:wa8yxm wrote:
IN the photo the air/ratio adjustment is lower left the WINDOW in the pipe
there should be (though I do not see it) either a slider or a twist around collar on that wide open window that reduces the air flow.
As I said I did NOT see it in the photo.
You did not see it because it is NOT supposed to have one. Doug
As stated:
Along with that change...burner/orifice assembly now no longer has 'air shutter'
