dougrainer
Nov 18, 2020Nomad
Scott M wrote:
Just wondering, if both the refrigerator and water heater are having the same issues, could it be low pressure on the main propane regulator? I may order an manometer to check propane flow?
What issue with the refer? You did not state problem with the refer.
Light the Range Burners, then Fire up the Water Heater on LP. Fire up the Furnace. Watch the Range burners with this LP load. The burner flames on the range should not fluctuate or pulsate or diminish. If they do, your LP regulator is BAD. Brand New, It needs replaced not adjusted. Doug
