neschultz
Apr 23, 2019Explorer
newman fulltimer wrote:
Your converter is frying itself with no battery hooked up
I agree it should have a battery hooked up. It also sounds as if you are describing a loose solder connection on your terminal. And that will cause heat and a poor connection. If true, you need to get an electrical tech to repair it before it gets worse or starts a fire.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
