BB_TX
Apr 23, 2019Nomad
I agree with above about the connections. Loose connections and poor wire crimps cause resistance and resistance and current create heat. Too much resistance and too much current results in overheated wires. Disconnect all power and check wire coonection on all AC hot, neutral, ground, and 12 volt wiring in your circuit breaker and fuse distribution panels. I checked mine shortly after buying new and found about half not properly tightened.
If it was more current than the wire was deigned for the fuse should have blown before it overheated.
