wa8yxm
Apr 24, 2019Explorer III
time2roll wrote:
Burnt areas probably have a loose connection. Replace the burned components and tighten/inspect the rest.
Otherwise what is the make and model of the panel? Might be best to replace the entire unit.
Bingo. You may need do nothing but re-solder but without seeing the board I can not be sure..
I just bought a new soldering toy (Benz-o-Matic) eats butane like a torce -a-fire but man does it get 'er done.
