Joe417
Sep 13, 2017Explorer
Manual said requires an authorized service tech. That usually means it was designed by an engineer without common sense, meaning that you have to pull the case off.
Probably an easy task, but I do this kind of work daily.
Hopefully it uses common components, but you may have to order some exotic bulb that the same engineer designed into it.
Still a lot cheaper than taking it to a repair shop.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
