DLO
Diesel locomotive cable
https://skycraftsurplus.com/20-awg-dlo-2-kv-black-blk-20-awg-rp5878.htmlIt is the best quality cable I have ever used. Notice the multi sheathing. The outermost layer may be a much as 10-times tougher to cut or abrade than the stuff West Marine or Genuine Dealz, sell.
The inner layers are water and gas-proof. Acid proof, chemical proof.
I use RED shrink tubing to ID positive cables. DLO cable is black.
The tin plating is three times as thick as what's on, Anchor Wire
Rope stranding for best ampacity.
And Skycraft sells it at 50% off.
But 30' is the minimum purchase of 2/0 size
3/0 rated terminals highly recommended because 2/0 won't fit. Way too tight.
Far and away better cable than simple welding cable which has sheathing that has no cut or abrasion resistance.
Skycraft is in FL. The wire ships from a west coast warehouse.
