Gulfcoast's avatar
Gulfcoast
Bus battery charging...
I need to keep the batteries in our school bus topped off so they will last longer. Just simply trickle charge the two 8-D batteries and nothing more. It just sits under a shed and the batteries go down from not being used that often.
I need to use solar since the nearest power (110v) is about 300 ft away. About how many watts would it take to keep the two 8-D batteries topped off year round? We are in the southeast USA, and the bus is 24-volts.
One more thing... it seems wasteful to go from 12v solar to a 110v inverter, then back to 24-volts to charge the batteries.
Thanks for your help.
  • Hi,
    An 8 D is usually in the 250 amp-hour range. For the rock bottom wattage about 60 watts might keep them charged, but only in PERFECT solar conditions. It also depends on the chemistry. Are they AGM or flooded?
  • Hi,
    No need to use an inverter at all. There are lots of solar charge controllers that will work magnificently @ 24 volts.
    I'd recommend about 120 watts per 100 amp-hours of storage @ 24 volts. That probably means about 320 watts of panels.
  • Unisolar 24v 136w $99
    MS Sunsaver 24v controller $70
    #12 or #14 wire is probably fine with 4 to 5 amps max.
    I think the controller needs to be connected to the battery BEFORE the solar is applied. Need a switch on the solar to turn off before you disconnect from the bus.
    This system will safely connect the panel direct to the battery with no added inverter or charger.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
