Mar 27, 2022Explorer II
Gdetrailer wrote:I didn't say buy this cheap cr@p. I was using that for illustration.
Buy poor quality crimps like what you linked and you get poor quality covers..
You CAN use the crimper I linked for insulated butt connectors and it works much better with much more reliable connections than the tool associated with with your link.There is more to a proper crimp than a pull test. You want to minimize connector resistance without reducing the mechanical integrity of the materials.
Notice how much more area an insulated crimp tool compresses compared to a non-insulated tool. It compresses more material onto the bare wire, creating more surface contact, creating less resistance. The tool is designed to provide maximum compression without degrading the materials or jeopardizing the insulation during a full crimp cycle. The key is FULL crimp cycle.
The crimp barrel of an insulated crimp connector has thinner walls compared to a non-insulated barrel. A non-insulated crimp tool is not designed to properly compress the materials. It penetrates a small portion of the thin walled barrel and improperly deforms the material on either side of this penetration area. This improper deformation creates more resistance compared to a proper crimp and weakens the barrel material. This can be easily verified with a micro-ohmeter. Vibration over time further weakens the material.
Manufacturers design proper tools for different types of crimps for a reason, function and reliability.
I have for 30+ yrs used the style of crimper I limked on insulated and non insulated crimps with 100% success rate..So now 30+ years of wrong makes a right? If you want to keep using the wrong tool knock yourself out. I have to ask, why use insulated crimp splices if you are going to negate the insulation feature by piercing a hole in it?
Maybe you are using the cheap stuff?
The other style, yeah I have one, somewhere laying around in the bottom of a tool box, too many crimps that pulled apart with that style to care to count..
I prefer soldering myself but over the yrs have learned on this forum that there are too many folks who feel crimping is vastly superior, I am not one of those folks.. I will take a soldered connection anytime over crimps, crimps are for speed, not quality.. Spent too many yrs of my life repairing crimp connections.Heat from soldering weakens the wire strands. But, properly done, cleaned, protected and restrained I agree, it's a better connection. However, excess vibration will destroy an improperly restrained solder connection.
If you want the very best crimp splice the world has to offer, use These
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
