LittleBill
Mar 27, 2022Explorer
Cummins12V98 wrote:
"OP here: Someone asked about voltage -- this is 12 volt. And again, thanks for all of the advice."
I asked because the answer matters depending if high or low voltage. Yellow butt connects will work but INMO I would use a RED twist nut. Strip back wires 3/4" twist them together and turn the connector until tight and the wires start twisting. Once that is done i would wrap the connector and wires with good quality black electrical tape. They will be a strong and GOOD connection.
AMAZON
Gardner Bender 25-086 WingGard Twist, 22-6 AWG, Electrical Nut, 25 pk, Red Wire Connector, 25 Pack, Count
Visit the Gardner Bender Store
4.7 out of 5 stars 539 ratings
$6.32
twist nuts in a vibration environment with stranded wire? Yea I would fire a person if they tried that with me. I have seen those things fall off in a house by touching them. they absolutely destroy stranded wire as well if you over tighten them even a half a revolution too far.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
