LittleBill
Apr 03, 2022Explorer
StirCrazy wrote:MEXICOWANDERER wrote:
No crimp heat-shrink terminals with solder just about mandates use of a electric heat shrink gun. They're inexpensive at Harbor Freight.
The above terminals do not use regular 60/40 electronics solder. A third metal card Bismuth is added and it reduces needed to melt temperature by some forty degrees.
I just purchased a box of no crimp heat shrink butts for 26-24 wire. The insulator is transparent clear.
I hope this helps someone and at least, is entertaining.
Be carefull with thoes, a couple other groups I am in for other hobbies jumped on that bandwagon. they are natroious for producing cold solder joints and cracking.
look back a couple posts, I made a video using them. They work fine if you take your time.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
