Adventurer_Buck
Apr 03, 2016Explorer
DFord wrote:
Adventurer Buck,
At least one of them is normal. If the engine isn't running, when the brake peddle is pressed, it's normal to hear the HydroBoost/HydroMax assist motor run to provide help with braking. It's an electric motor running a pump that you hear. The assist with the motor running comes from the power-steering pump. All Ford V10 F-53 chassis do it.
If you've got another noise, I'm not sure what would be causing that.
I've always looked at the "buzz" sound when the key is in the ON position as a sound that indicated power was at the ignition and ready to turn-over the motor. Would turning the key to ON (not accessory) cause the Hydroboost's electric motor to turn-on or would there be another electric driven instrument?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
