OldF__t
Apr 04, 2016Explorer
The "buzzing" is completely normal. The electric pump runs under two conditions. One if the pedal is pressed with key off and two if the ignition is on but the engine isn't running. The second condition is important as it gives you braking assist if you are going down the road and the engine quits.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
