Pangaea_Ron's avatar
Pangaea_Ron
Buzzing sound from brake pedal if depressed before starting
It seems odd that the administrator would refer a search here for this thread, but would not provide an actual link? Or am I missing something?
  • darsben wrote:
    Looks like the OP posted twice the other link is at
    http://forums.motorhomemagazine.com/index.cfm/fuseaction/thread/tid/28819023.cfm
    The forum tech support was the wrong area for the original post.
    Thanks for the clarification.
  • don't know what vehicle or hydraulic systems you are asking about
    but on our Safari DP
    the steering and brakes are powered from a 12v motorized pump
    and the relay (or something) for the pump will buzz, when the brake pedal is pressed IF the engine & thus the alternator, is not running
    they work but the buzzing alerts you to the fact the engine is not running
    this way there is power steering and power braking even if the engine fails
  • Looks like the OP posted twice the other link is at
  • well then the thread is at
    http://forums.motorhomemagazine.com/index.cfm/fuseaction/thread/tid/28819357.cfm
  • > "Buzzing" from Ignition and Brakes: Ford F-53
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28819357.cfm
    Is this the same problem?
  • darsben wrote:
    looks like your thread was eliminated.
    Private mail an administrator and ask why
    Actually, it was someone else's thread that I was curious about, as I have the same issue?
    I like the quote at the bottom of your post. . . me too.
  • looks like your thread was eliminated.
