jerseyjim's avatar
jerseyjim
Bypass INverter?
2001 National RV Dolphin. OK..it is old...but good. But..like some things old, parts are starting the replacement chapter.
Some 2 years ago, replace the CONverter, as it was getting "weak". I called that preventive maintainance.
Now...problem with the INverter...I'm guessing failure. It is a "Dimensions Unlimited, Model: DUI 12/400. A green light indicates power going in....but nothing is coming out. The INverter controls the very front of the motorhome, TV and all that, one outlet near the floor and a kitchen outlet mainly for the coffee maker. It also (strangely enough) controls the 2 outlets in the bedroom!
Can't find anything on it on the 'net (too old?)...I have the owners manual that shows a pretty basic schematic.
What I think is the BIG problem...it is a PLUG IN....and I just want to bypass the whole thing....to replace it would be around $1000, something i just don't want to do.
Wires go into the back panel of this thing (never saw them)the INverter itself is screws into the wall...a plug comes out the front and (of course) plugs into a 110 outlet that gives me the power up front and the bedroom.
Again...I'd just like to remove it...any ideas so I don't blow myself up? Or have a fire? From experience, I know I cannot put anything like a space heater on that line....it pops the GFI on the unit.
  • You have made confusing statements and it's hard to know what's going where with the wiring
    Your inverter has a GFI out let on the front
    WHAT'S ON THE BACK?
    Is there a 120v cord with male plug ?
    If yes then it has 120v power coming in and has pass thru
    Just plug the cord from the front, into the power outlet feeding the inverter
    If there is only red and black 12v wires going to the battery, then no pass thru
    You can take the CORD END that used to plug into the front of the inverter and plug that into an extension cord
    Take pictures of ALL the inverter wiring connections and post them here
    Do Not use a cord with two male ends to back feed into your RV circuits
  • " (damage may occur if an ) external AC power source is applied to the inverter’s
    AC outlet or its hardwire output.
    CAUTION: Be sure the inverter's circuit breaker or
    fuse are turned “OFF” during installation."
    EDIT--it has a "terminal block" for hardwiring the 120v output.
    The manual linked earlier suggests it has a hardwire outlet but the drawing in that manual does not show it. Perhaps it does have one, and that is what powers his front receptacles etc. ????
    He says it no longer works. The manual refers to an inverter circuit breaker and a high temp shut off.
    It is very confusing. Note the manual warning not to back feed the inverter's 120v outlets with 120v. Also note the general warning not to ever use a "suicide" (male plug at each end extension cord) set up to power a circuit.
  • Roadpilot wrote:
    You have a Magnum Dimensions 400 watt pure sine inverter. Input is +/- 12vdc and a chassis ground. Output appears to be via a normal wall plug.
    Magnum has a trouble shooting procedure on their web site:
    Trouble Shooting
    I'd try that first. If it's dead they have a phone number in the trouble shooting page. Maybe they repair these?
    If not I'd buy a 400-800 watt pure sine inverter woth a plug output and install in your failed units place.
    Room should not be an issue because you unit is huge and it weighs 14 pounds. You'll be amazed at what will replace.
    The OP has a 2001 RV with a 2001 Dimensions Inverter. HOW could he have a Magnum Dimension when Magnum was not formed until 2006??????
    NOT THE SAME INVERTER! Same name but not the same Inverter
    The OP's Dimension was what a lot of Motorhome makers used back then. It has a 120 plug pigtail that plugs into the wall outlet in the cabinet. All he has to do is jump the 120 wires together and that will bypass the Inverter. Back then they thought 400 watt was adequate for entertainment systems. They were for a few years and then as the Inverter aged, they did not continue the 400 watt output. Here is a link to the smaller 300 watt. Doug
    https://winnebagoind.com/resources/service/pdfs/2002-06%20Dimensions%20Power%20Inverter.pdf
  • Kudos dougrainer for excellent detective work.
    Most pass through inverters use a sad printed circuit board DPDT relay. A separarte full size frame relay rated 30 amps like a GTE brand found on eBay is easy to wire and will outlast a circuit board relay 50 to 1. Enclose in a box. Use the normally closed contacts as the power pedestal circuit and the magnetic closed circuit for the inverter.
    This is a fun project. I've done many of them to resurrect failed pass through perverters.
    NOT detective work. I KNOW what the **** I am doing:B I worked (we also sold) on National from 1993 until 2006 when they went under and Newmar also used the Dimensions model 400 watt 18 years ago and we also sold and I serviced them then. Still do. Doug
    MY experience is because I have been in the RV service business for 38 years and I DO remember OLDER systems.
  • Thank you all again. This morning I removed the INverter.Did some easy rewiring...and it all works.
    It just wasn't worth fixing....16 years and never used it. And and all those pop rivets to be drilled out just to replace the GFI ? Nope..but thanks again
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
