3_tons
Sep 05, 2023Explorer III
StirCrazy wrote:Treefrog wrote:
California requires a smog test for diesel RV registration starting 2024. I called my local Cummins dealer and he had no suggestions on how to bring an old design into compliance.
Have you heard of any?
and why are you worried about this? they wouldn't have to meet any more strict guidelines than what they were designed to....
The issue is going to be what legislation is going to follow to newer models and how is this going to affect people that have ‘modified diesels’
away from the design spec for that year. so unless you have modified it and it is running well, you should have an issue.
This might be true if it applied only to modified engines, and we opt to dismiss the fact that California has a history of banning perfectly good diesel engines (arbitrarily beyond a certain year of manufacture) and requiring a hole be drilled through their engine blocks - FWIW, this is all done by agency regulatory fiat (overreach) rather than by representative law making, this the basis of Huxley’s ‘Brave New World’ - though the excepted new normal…
