gandydancer's avatar
gandydancer
Cable connector tool
Can anyone recommend a F- connector tool for use when hooking up cable coax at the campground? I have trouble getting my fat fingers around the nut to properly tighten.I use slip-on connectors now but I think there is signal leakage with them. Thanks
  • jkwilson wrote:
    Don't think that is what you want. That releases the security sleeve you see on hotel cable connections.
    On second thought, you are correct. It would work for crimped connectors but not for compression type, which is most common now.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
