fulltimedaniel's avatar
Jan 15, 2017
Cable TV - Antenna Cable Question
I have had my trailer for more than two years now and despite full timing for all of that time I have never hooked up to the outside cable (Park Cable TV). I have used the over the air antenna a few times and it does work.
However when I tried to get a signal to my smart TV via the Park Cable the scan for channels turns up nothing and I get the No antenna-connection error msg on screen.
I rechecked all the connections including pulling the plate on the trailer where the cable connector is to see if there actually was a connection made there. I also changed the connection to the park from my site to the site next door as a test...nothing.
I have tried connecting with the signal booster on and off. All of the connections are made to the proper place. (there is only one Coaxial conn. on my TV)
So without a signal tester for Cable (@ over $30) I cant tell if it is the Park (unlikely) or something in my rig.
Does any one have any ideas?
Thanks
  • You may have to get a cable box from the park office. Many cable systems now require this interface for cable to work.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
