ItsyRV
Jun 17, 2019Explorer
Big_steve wrote:
Do most folks use an in-line surge protector on their cable tv coax cable? If so, where are you connecting it to ground?
I made mine using a standard coax cable in-line surge protector. It hooks up to the campground's cable connection using the attached 6" coax cable with a standard coax cable hooking to the other end. I had attached a short 18" bonding cable with an alligator clip to the ground screw. The alligator clip just attaches to the electric or water ground clamp at your spot.
The coax cable surge protector (not to be mistaken for a ordinary grounding connector) was about $25 and the bonding cable was $5 from a welder who didn't need it.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
