tessab's avatar
tessab
Calculating voltage drop
In determining which size wire to use, what load do we enter when calculating voltage drop when adding a 50 amp RV site when the electric service is a 240 volt, 50 amp breaker and RVs technically run on 120 volts? Do we count the RV as 50 amps, or can we count it as just 25 amps since the RV essentially has two 120 volt, 25 amp circuits?
