MrWizard
Dec 27, 2018Moderator
The longer it is , the bigger the heater needed
And I like the 8000, and no if you need it, it won't be just a few hours just because it is bigger
If you need a 3000 all night then you will need the big one set on low all night
They will burn the same amount when set to the same btu settings
The big one won't go as low as the 3000, low in the big one is more heat than low on the little one
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related Content
- Feb 01, 2026Community Alumni
