cannesdo
Jul 02, 2019Explorer
cannesdo wrote:MDKMDK wrote:dougrainer wrote:
They do NOT make a 120 volt Tankless Water Heater for RV's. Doug
Was thinking the same thing. The only way I can think of to get instant, high volume, continuous flow, hot water in an RV, is from a propane fired device like a Truma AquaGo Comfort Plus.
Thanks! I'm thinking the same.
I called Truma and the flow output is too low for the water to stay warm and they are only certified for RV use. But I know there are others that run off of propane with higher flow outputs. I think propane is key. I'll let you know if/when I find the right one. ;)
