John_Burke
Jul 03, 2019Explorer
CANNESDO wrote "Yes, thanks...that sounds good but what is the gallons per minute rating? If I don't have a good output the water in the tub will cool before the tub is full. That's the trick. Finding one with the output capacity that's w/in the Amp rating"
Fill your tub first and use a small pump with the Eccotemp or similar portable, tank less, propane water heater to circulate the water from the tub.
That way you can keep the water temp to your liking for as long as you want.
It is like a hot tub, they just circulate and heat the same water.
