maillemaker
Jun 11, 2018Explorer
Looks like a bypass for when the heater valve is shut. If the heater is fed directly off the water pump, when the thermostat is closed and the heater valve is closed, there's no flow through the pump, causing it to cavitate and heat up.
Just a guess.
Thanks for the info. Where is the "heater valve" located? I'm not familiar with that.
Steve
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
