wopachop's avatar
wopachop
Can AUTO mode damage A/C from frequent shutdowns?
Have a dometic air conditioner with the wall mounted controller. The A/C reacts differently based on the FAN setting being low, high, or auto.
If the fan is set to low the A/C runs 24/7 on the low fan speed and i can hear when the compressor kicks off and on.
If the fan is set to auto the A/C will bounce around between running on high, low, or completely shutting off.
I have heard A/C guys say you need to let it rest for several minutes after a shutdown. It seems like my RV rooftop A/C can turn off and on within a minute. It also sounds like a long pause of nothing when it switches between high and low fan.
To battle this i set the controller temp super low so the A/C stays running. But i would prefer if i could set it to 85F when im gone. Not sure which of the fan settings would do the least amount of wear and tear on the ac unit.
  • When the outside temp gets in the hi 80's, I switch my units from auto to hi. This results in a more even cooling as the air keeps moving when the compressor turns off.
    IMO, the only excessive wear on the fan motor not running on auto will be in the bearings.
    Short cycling of the compressor will normally trip the internal overload device. If this happens a lot you could damage the overload to the point it may not reset.
    Also, short cycling results in higher than normal amp draw, and this could damage the start cap/device.
  • When it "seeks" between high and low fan, it's the fan shutting down - not the compressor. If you listen, you should be able to hear that. It's irritating but shouldn't do any damage. When those conditions occurred in our previous rig, I would just put the fan on high full-time and let the compressor cycle on and off as needed. The Coleman Machs in our new rig are set up differently, though.
    Rob
  • 3_tons's avatar
    3_tons
    Explorer III
    Perhaps member Doug can enlighten us a bit more, but from what I know about my Coleman Mach 1, regardless of the fan mode, etc. once the compressor cycles to Off there is a 3 min time delay before the compressor can restart again, this to allow time for the high-side of the compressor to equalize (or bleed down) to the low-side, however can’t say whether this attribute is driven by the air conditioner or by the t-stat...
    3 tons
