3oaks
Feb 05, 2017Explorer
If your utility trailer doesn't have brakes, I would just use the EZ-lube set-up as is. No need to worry about leaky seals allowing grease on brake linings.
If it were me, I would disassemble them once for inspection to check if all was good and bearing clearances were within specs.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
