- Cummins12V98Explorer IIII like having a clear elbow before so you and see when it's almost drained.
- BobboExplorer IIII think it is. Now, if you were driving down the road with it hanging on there, I would give a different answer. Driving down the road, when you hit speed bumps or potholes, you have a dynamic load that is many times higher than just the weight of the macerator hanging on there while it is sitting still.
- TurnThePageExplorerIs it silly to worry about the weight of the macerator hanging off the drain?
- BoomerwepsExplorerMy only concern would be getting that regular sewer hose fully drained, plus an extra item to clean.
But mechanically using it that way, no problem. - wa8yxmExplorer IIIDone it up to around 30 feet on one occasion. (Had to use a portable battery for the pump).
At least one model comes with a short length of 3" hose on the inlet (This model is mounted in the RV.. gives you the choice of using the pump or a straight 3" stinky slinky). - buckyExplorer IIThat's a great idea. Thanks for sharing.
- Boon_DockerExplorer IIIYou're Welcome
- TurnThePageExplorerThanks for the feedback!
- Boon_DockerExplorer IIII added 3 feet of hose to my macerator and it works just fine.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
