ShoelaceExpress's avatar
Mar 29, 2017
Can I charge/maintain 12V batteries in parallel?
We had an older pop-up, but never had a battery on it. We recently upgraded to a 31' Bullet Premiere 31bhpr. SOOOOO HAPPY RIGHT NOW! haha.. ok, onto my questions about charging/maintaining:
The new TT needed a new battery, so I ended up purchasing two deep-cycle RV/marine batteries to install in parallel. I haven't hooked up the batteries yet, but will shortly.
1. I have a 12v battery charger/maintainer at home. Is it possible to hook the two batteries up in parallel in my garage and charge/maintain the batteries like that? Or should I just go buy a second charger/maintainer?
2. For while camping, I bought 2x40W Coleman solar panels (80W total). I need to find a iMob 4-in-1 connector so I can add both 40W panels together before the 7A charge controller - does anyone know where I should look? I've found them for $7 online, but they want $25 shipping to Canada.
3. Since the batteries will be in parallel while connected to the trailer, is it ok for the solar panels / charge controller to be connected to the parallel batteries, or should I disconnect one at a time and charge them? Alternatively, I could disconnect them from parallel and use a panel and charge controller (since I have two of each) on each battery. Just wasn't sure what the proper charging technique is.
Thanks!
  • There is no power available where I keep the trailer parked, unfortunately, so my only option at the moment is removing the batteries and keeping them at home.
    So while connected in parallel in my garage, I'd have the batteries connected positive to positive, and negative to negative, and then connect my charger/maintainer to the negative on one battery and positive on the other battery?
    When connected in parallel on my trailer, just connect the charge controller in the same way? It doesn't mess with any electronics or the converter in the trailer? (sorry, probably dumb question, but I'm new at this).
    I don't believe the trailer has a battery disconnect switch either - do you recommend installing one for while the trailer is parked for a couple weeks at a time between camping trips?
  • There's no problem with charging batteries in parallel, especially identical batteries. Obviously it takes about twice as long as charging one battery, since you have twice the battery capacity, assuming the same state of charge.
    If you have power where you store the trailer, you can simply plug it in and let the converter keep the batteries charged, which would be easier than toting them to the garage and hooking them up to the maintainer (and eliminate any possibility of hooking something up incorrectly sometime). You could also just hook up the maintainer in the trailer if you didn't care to have the converter and other parts of the trailer electric system live all the time for some reason.
