msmith1199
Aug 16, 2023Explorer II
DallasSteve wrote:
I have a Jayco Jay Flight. I filled the fresh water tank, but now water is draining out from the Low Point Drain under the trailer. Is there a way to close that drain or is it supposed to remain open?
Edit: Never mind. It stopped draining water and the Fresh tank reads full. I guess it's just an overflow for when it gets too full.
As you fill your water tank it expands a little with the pressure from the hose. So by the time it hits the overflow there is some pressure to the tank. So even if you turn it off right a way, the over flow may still flow for a while. My current motorhome and my last motorhome did the same thing.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
