time2roll
Jul 16, 2018Nomad
If you have an empty branch circuit in the 12 volt distribution panel with proper amp rating then it will work.
Many controllers require a battery connection at all times if the panels are connected or the controller can be damaged.
Depending on power and connections you will get better performance with the controller close to the battery.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
