dougrainer
Mar 04, 2014Nomad
Commutator wrote:
Of course there's a breakaway battery, but it's not relevant. I'm not going to use it to power a camera for the obvious safety reasons, plus that would make the camera always-on which is worse than just having it on whenever the truck is connected. I only want the camera on when the truck is connected AND running.
I'm not going to rework the 7 way connector to get an ignition-hot feed to the trailer so I can use a relay. If I can't find the equivalent of a vsr that works without a battery on the load side of the relay, then I'll just feed the camera from the running lights. But my strong preference is to have it automatically on when truck is running, and off when truck is not.
Thanks,
Fred
I connected the Camera to the rear Running lights on the rear of the trailer. You just turn the Truck headlights OR just the running lights ON to activate the Camera. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
