Chris_Bryant
Mar 04, 2014Explorer II
This Sure Power unit does what you want- closes the relay when the battery is above 13.2 volts. You don't need an ignition tag line (even though it has a connection for it).
As long as the camera draws under 100 amps, it should be fine :D
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
