Chris_Bryant
Mar 04, 2014Explorer II
wa8yxm wrote:
Ok, in that case, take my last post and remove all reference to "HOUSE".
Just charge the brake battery when parked using a battery tender
And use the charge line from your towed to power the camera.. TWO independent systems, one powered by the truck and the emergency brake battery operated.
No need for any fancy electronics, just the already existing isolator in the truck.
You could still charge via the truck- just add a diode in the charge line after the camera feed. As long as the charge line was switched, it would work fine.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
