BFL13
Mar 24, 2019Explorer II
In gas mode, first clean the orifice (I soak it in mineral spirits, and blow through to get it to squirt like a water pistol) but the pros here have other ways). Your solenoid might be ok, don't know until confirmed orifice is clean. Check all wire connections to the solenoid too.
Bang on the flue above the burner slots to shake loose any soot flakes and clean out all soot that might have gone down the slots
On my 1991 3-way Dometic, the AC heater element was rusted out broken so no good. You can check for 120 at its blade terminals on the side of the board. There is a 120v fuse on the board itself (5a on mine) and a 12v fuse (3a on mine) to check.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
