L_MMusic's avatar
L_MMusic
Can I JUST replace the tank?
I have a ten year old Atwood XT 10 gallon LP and Electric Water Heater. The tank has corroded and is leakaing, but the rest of the parts are fine.
Can I JUST replace the tank? Can someone point me in the right direction?
Tank you very much!!!
  • YES....you can replace just the tank
    The tank is held onto the drawn pan by seal rings that are press fitted on combustion/exhaust chamber ports.
    Those have to be cut off to remove/separate pan from tank
    New tank comes with new rings/gaskets/insulation
    Same tank used for standard 10 gal and the XT 10 gal (GE16-EXT Model)
    New tank #91060 $204
    Atwood GE16-EXT complete...$671
  • Sure, but you will probsbly find it just as cheap to buy the whole thing.
    Yes. Just Google your exact Atwood water heater model number for a replacement tank.
