dougrainer wrote:
Atwood water heater tanks are constructed of a high strength aluminum.
The interior of the tank consists of a .0015 thickness of type 7072
aluminum (pure aluminum and zinc) that is fused to the core during the
rolling process. This material protects the tanks from the effects of heavy
metals and salts found in waters throughout the country. It is anodic to
these heavy metals and acts much like an anode in a steel glass lined
tank except it will last much longer. Aftermarket Anode Rods are not
required and should not be used and will void warranty
I know what the tanks are made of, and I know what Atwood’s recommendation is regarding anode rods. I disagree with them, and basic science is on my side. If an anode is used that is more anodic than the aluminum tank, the rod will deteriorate rather than the tank. That’s an indisputable fact. Also, Atwood cannot, and will not void your warranty for simply USING an anode rod or any other non-OEM part on their water heaters. They can and will refuse to warranty any damage CAUSED by non-OEM parts. So, If you choose to use an anode in an Atwood water heater, don’t screw up the threads in the process. Atwood’s water heater manual also states that the tanks CAN develop pin hole leaks due to the lining deteriorating, and in some cases it can happen quite rapidly.
If Atwood would warranty replace the OP’s 10 year old water heater because the tank deteriorated I’d feel differently. But they won’t, the warranty is gone.
I’d rather have a sacrificial anode rod than a sacrificial water tank.
