wnjj
May 19, 2015Explorer II
martipr wrote:
Thanks to everyone for the replies. However all I want to do is swap the outlets, nor rebuild the AC system. If it can't be done that simply then I will just live with the inconvenience of the reset being hidden behind the TV
Is the TV set receptacle causing the tripping or some other (i.e. outside) receptacle doing it?
My suggestion was to leave the existing one behind the TV, but rewire so that the downstream receptacles are NOT connected to the "load" terminals, THEN adding another GFCI on the next one in line. This way all receptacles are protected but if the nuisance trips are caused by anything but the TV receptacle, it's easy to reset. No new boxes or Romex required, just one new GFCI receptacle.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
