martipr
May 20, 2015Explorer
CA Traveler wrote:martipr wrote:Why assume? Buy a $10 household tester with GFCI test button and find out what outlets are on the circuit.
I assume the outlet behind the TV is a GFCI because it is on the wall behind the shower so I don't want to put a standard outlet there.
The GFCI is a safety protection device. However moving it from the TV outlet to the next downstream outlet would be my choice if a panel CB/GFCI is not available. The main outlets to be protected are any near water so I would not be overly concerned with not protecting the TV even though it's behind the shower.
Another option would be to run a new wire from the CB panel to a new GFCI outlet somewhere that's easy to reset and then connect the load side to the TV outlet replacing that GFCI with a regular outlet.
I worded that badly. I know it is a GFCI outlet, it has the reset button. The assumption is that a GFCI outlet was in this location because of the shower.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
