jrnymn7
May 21, 2015Explorer
road-runner wrote:And only one gfci per circuit... or they simply won't work. No way, no how, does the OP's rig have more than one gfci per circuit... impossible.Incorrect information. I have used multiple GFCIs per circuit, as multiple paralleled GFCI outlets on the same circuit, or as chained GFCIs (one downstream of another). If multiple GFCIs didn't work it wouldn't be possible to use a hair dryer or pressure washer on a GFCI-protected circuit. It also wouldn't be possible to successfully power an RV from a GFCI-protected circuit, which many RV owners routinely do.
Nevertheless, there is no need for multiple gfci's. But I admit I was thinking in terms of any downstream gfci being wired through (i.e; off the load terminals) of the previous gfci. My bad. I'm not a fan of pigtailing, as it creates more possible loose connections, and can make for a rather tight fit inside the box.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
