martipr's avatar
martipr
Can I move a GFCI receptacle?
The GFCI receptacle with the reset button in my TT is buried behind the television in the cabinet. Is there any problem with swapping it with one of the more accessible GFCI receptacle?
  • As mentioned, just put install a GFI breaker if you can find one to fit the panel.
  • As ENB said.
    I would check to see if it is indeed the first off the breaker. As I am sure many can attest, Camper wiring is not always done exactly as it should be.
    Hopefully you should never really need to reset it though!
  • Yes, there is issues with moving it. The GFCI receptacle must be the first in the circuit.
    One way is to install a GFCI breaker in the 120 volt distribution panel.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
