- TucsonJimExplorer IIAs mentioned, just put install a GFI breaker if you can find one to fit the panel.
- ChandalenExplorerAs ENB said.
I would check to see if it is indeed the first off the breaker. As I am sure many can attest, Camper wiring is not always done exactly as it should be.
Hopefully you should never really need to reset it though! - Yes, there is issues with moving it. The GFCI receptacle must be the first in the circuit.
One way is to install a GFCI breaker in the 120 volt distribution panel.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
