imgoin4it
Jun 23, 2015Explorer
If it is tripping the 20 amp house breaker obviously you cannot run the coach acnd without tripping. You can take a look at what else you may have on that circuit that could be disconnected and maybe reduce the load or more than likely you will have to get a qualified electrician to see what is required to install at least a 30 amp circuit.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
