2chiefsRus
Jun 23, 2015Explorer
If you turn off the converter/charger, you will remove the load of charging the batteries while you are trying to run the AC. We had friends who had a similiar problem - it turned out the freezer in the basement was on the same circuit the RV was plugged into. If the freezer wasn't running, the AC was fine but if the freezer kicked on, not enough juice left to run the AC.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
