rob_engineer
Jun 23, 2015Explorer
greenrvgreen wrote:
I'd start by replacing the breaker. It's cheaper and (IMO) more likely to be the problem.
If the AC won't run properly on a fresh breaker then it never did, not even for the PO. But before I bought a new AC I'd take a hard look at the wiring.
There are four bolts that hold a roof AC to the vent orifice. If you remover those you can press the AC up and on to the roof. Somewhere at the side of the vent orifice you'll find the AC hardwired in with thumbscrews. Before I went out and bought a new AC I'd try powering it directly via the hardwire connection, just to see.
Also, have a look around. Is the water heater on electric? The battery charger running? These things are FAR more likely to be the problem. Maybe your batts are dead and the converter can't stop trying to charge them.
All good thoughts. I already replaced the breaker. Even temporarily put in a 30 amp one. Still kicked after running for 5-10 minutes. I also cleaned the fins. They are not in great shape since the unit is 19 years old. I haven't tried direct power, but I likely will before buying a new unit. However, I know the generator supplied over 113 volt to the terminals even under load, so I think a wiring problem is unlikely. I'm coming to the conclusion that my old unit is toast.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
