Jan 09, 2019Explorer II
I would connect the WFCO to the vehicle battery input (red wire). This way the REDARC would behave like a boost/buck converter. You will be lucky to get >13.6V out of the WFCO. The REDARC will boost that to 14.6V when bulk/absorb is needed.
If this is in a TC, use an isolation relay to disconnect the truck line when the WFCO is turned on.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
