Jan 09, 2019Explorer II
"Charging from one source at a time is always the most ideal circumstance, as two charging sources at once can cause early float stages, and an incomplete charge.”I can see this happening if both chargers are smart enough. They may trick each other into thinking the battery is charged.
However, I believe the WFCO is timed. As I understand it, it will stay in absorption mode for a day or so, then go to float. I have never seen my WFCO put out anything other than 13.6V to 13.8V. And it's powered on 24/7.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
